Oscillation of adaptive time step--please help |
February 7, 2003, 16:26 |
Hi, there: I met with some special problem when using adaptive time step. what I did is rather simple, using smaller dt when quantity F changed fast with time, and using larger dt when F changed slower with time. But everytime when I switched the dt, I have some oscilation in F, which is not there if using uniform dt.
BTW, I used the same adaptive method for my 1D codes, it worked. but for 2D, such problem comes. does anyone know how to solve the problem? I appreciate your advice and suggestions very much! |
February 9, 2003, 03:17 |
Re: Oscillation of adaptive time step--please help
You are required to switch Dt smoothly in between, just as for grid.
February 11, 2003, 16:19 |
I have tried to change it smoothly, but seems to me no much help. BTW, I use semi-implicit scheme, so that I need not to abide by the CFL limit. Is it true?
Display Modes | |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 23:50 |
Intermediate step during a time step | Burn | OpenFOAM | 0 | July 16, 2009 11:01 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
