Multiphase flow modelling using CFD review/book
Old   February 12, 2003, 01:51
Default Multiphase flow modelling using CFD review/book
Matthew Brannock
Can any body put me onto a journal review or book that looks at multiphase flow modelling techniques in CFD? I've really had no luck with finding a comprehensive review (well, even any review that covered only one of the topics below). I'm after something that would cover Lagrangian-Eulerian & Eulerian-Eulerian methods (including drift-velocity, drift-flux, slip and homogenous models).
At the moment I'm looking at implementing a homogenous model (core CFD equations with a scalar transport equation of solids concentration including settling velocity as a function of the scalar), so I'd like to see the advantages/disadvantages of it compared to other methods.
Old   February 12, 2003, 04:40
Default Re: Multiphase flow modelling using CFD review/boo
aid
There isn't any specific review/book in two-phase flow but there are many perfect articles in two-phase flow. for simplicity for example many people consider drift flux model where u_{1} = u_{2}, where I've considered it as u_{r} = u_{2} - u_{1}, can you see the difference,
have a look to:
Numerical simulation of compressible two-phase flow model based on the Riemann problem. ACOMEN 2002, Liege, Belgium, May 28-31, 2002.
this one of the best in two-phase flow models;
Stewart, H and Wendroff, B. Two-phase flow: models and methods J. of comp. phys. 56, 1984, 363-409
and many others.
Trust me there are many different models as many numerical solutions for two-phase flow. I'm telling you this after more than 3 years in mathematical and numerical study of two-phase flow models, one more fact as well, there are a large number of derivations of the balance equations are available for two-phase flow applications. The fact that each researcher is primarily interested in a particular system of flow regime has led to conflicts and differences in the resulting equations.
I advice you to understand the mathematical analysis of two-phase flow models, is it ill-posed, well-posed etc. this will help you in your numerics.
If you need any article or help just let me know.
Old   February 13, 2003, 00:11
Matthew Brannock
Thanks very much for that. The Stewart paper was quite useful.
I just found a paper that was more situation specific for me (ie water clarifier design). I think it might be reasonably useful also.
D. Lakehal, "On the modelling of multiphase turbulent flows for environmental and hydrodynamic applications," International Journal of Multiphase Flow, 28, 823-863, 2002.
Old   February 13, 2003, 14:28
Andrea Panizza
Dear sir, I would like to ask you some references for a specific case of two-phase flow, namely solid particles in a gas flow (aerosol), in incompressible to slightly compressible regime (M <0.33), and at very low pressures. Expecially books would be useful. Thank you very much for your attention,
Andrea Panizza
Old   February 14, 2003, 09:19
su
may be this will help
S.T. Soo
Fluid Dynamics of Multiphase Systems
Waltham: Blaisdell, 1967
why not to be in this
http://www.newton.cam.ac.uk/programs/NPA/npa.html
Old   February 14, 2003, 15:25
Tony
There is one particular issue in J Comput Phys on multiphase flows. The following reviews are quite comprehensive.
Osher S and Fedkiw RP, Level set methods: an overview and some recent results, J. Comput. Phys. 169, 463-502 (2001).
Tryggvason G, Bunner B, Esmaeeli A, Juric D, Al-Rawahi N, Tauber W, Han J, Nas S and Jan YJ, A front-tracking method for the computations of multiphase flow, J. Comput. Phys. 169, 708¨C759 (2001).
For solid particles, things are easier (I guess). You may look at
R. Glowinski, T.W. Pan, T.I. Hesla, D.D. Joseph, and J. Periaux, A fictitious domain approach to the direct numerical simulation of incompressible viscous flow past moving rigid bodies: application to particulate flow, J. Comp. Phys. 169, 363 (2001).
CFD modelling of two phase flow in cyclone separator rajeshkunwar Main CFD Forum 0 April 21, 2009 09:35
Multiphase flow for flow around ship gundul CFX 5 September 2, 2008 16:06
multiphase flow modelling, Drag model Anant CFX 1 February 4, 2008 04:18
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 16 October 2, 2000 09:15
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 09:21
