Difference between structured & unstructured mesh
Old   February 20, 2003, 00:10
Default Difference between structured & unstructured mesh
Andrew
Hi
What's the difference between structured mesh and unstructured mesh? Thanks.
Andrew
Old   February 20, 2003, 05:41
Default Re: Difference between structured & unstructured m
Marc
Hi Andrew,
there are two levels you have to look at, when you want to decide about if a mesh is structured or not. A structured mesh can only be a hexahedron itself, where the parallel edges count the same number of nodes. When you connect these blocks together you get a block-structured mesh, which is still a structured mesh. But the shape is not sufficient for a structured mesh. It is also neccessary to look at the numering of the nodes. A code, which uses a structured mesh, needs special (structured) numbering (CFX-4). A tetrahedron mesh is, in general, unstructured. Nobody would create a structured mesh and then devide the hexas into tets. Did that help you?
Greetings, Marc
Old   February 20, 2003, 09:40
Smith
Please see this previous posting :
http://www.cfd-online.com/Forum/main...cgi?read=12475
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Mesh Mignard FLUENT 2 March 22, 2000 06:12
