how to create airfoil section for NACA0012?
Old   March 8, 2003, 14:15
Default how to create airfoil section for NACA0012?
stone_gargoly
HI, Now I am working for NACA0012.CAN ANYONE HELP TO CREATE THE NACA0012 PROFILE OR TELL ME THE METHODE. THANK YOU
Old   March 10, 2003, 02:20
Default Re: how to create airfoil section for NACA0012?
Praveen
See this document
http://www.aoe.vt.edu/aoe/faculty/Mason_f/CAtxtAppA.pdf
Old   March 10, 2003, 04:49
Mark
Theory of Wing Sections: Including a Summary of Airfoil Data by Ira H. Abbott, A. E. von Doenhoff
This book should have everything you need.
Mark
Old   March 10, 2003, 15:48
Jonas Larsson
Abbot & Doenhoff as recommended by Mark will surely help you as well as provide you with an invaluable reference for any airfoil related work in the future. If you are lazy you might want to check out the /Resources/Refs/Airfoils section at CFD Online. There you can find links to several web-sites which will give you both coordinate lists and free programs to generate 4-digit NACA profiles.
getting airfoil surface to be recongized for tri mesh josip76 ANSYS Meshing & Geometry 4 June 9, 2011 22:48
[GAMBIT] Periodic BC truffaldino ANSYS Meshing & Geometry 4 June 5, 2011 06:39
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 04:49
Calculating polars from 2D airfoil coordinates... wlvrn Main CFD Forum 0 August 18, 2010 18:43
LiftDrag utility from v12 to v141 cfdphil OpenFOAM Running, Solving & CFD 2 December 5, 2007 05:49
