Turbulence Modeling
Old   March 18, 2003, 08:20
Default Turbulence Modeling
Valdemir
Hi Dear,
What justify the use of turbulence modelling?
Valdemir.
Old   March 18, 2003, 15:33
Default Re: Turbulence Modeling
Frederic Felten
Hi there,
Well, turbulent flows are characterized by a wide range of scales (both spatial and temporal). With the actual computer power, the idea of solving for all the scales (no modeling - DNS approach) is only affordable for simple geometries with a limited range a scales involved.
Therefore, for engineering purpose, and/or in case of complex flows, one has to separate the scales so that you don't have to solve for all of them. With this idea,some scales are going to be resolved (usually the larger scales) and some others will be modeled. That is the idea of turbulence modeling!!
Now as far as the modeling is concern, several approach are possible: RANS, LES, Galerkine-POD ... It is up to you to decide which approach is the most appropriate in terms of cost, reliability and accuracy!!
For more insight on: Why do we need a turbulence model?, just grab any book on turbulence modeling (like "Turbulence modeling for CFD" by Wilcox, 1993).
I hope this helps. Sincerely,
Frederic Felten.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
A small confusion regarding terminology of turbulence modeling Chander CFX 6 September 28, 2011 20:05
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 11:48
