How to solve equations from Penalty FEM in Fluids?
Old   March 11, 2003, 10:14
Default How to solve equations from Penalty FEM in Fluids?
Yiling
Hi! everyone,
I am learning and practicing penalty finite element method used to solve the incompressible flow. After the typical formulation of reduced integration method, a resultant systematic matrix is formed, but how to solve this equation whose some entries in the coefficient matrix are nearly infinite? General successive over-relaxation method fails to converge for this type of equaton, although the direct method such as Gaussian elemination method does work, but the extra requirment of storage forbides its use for large equation sets.
Can you share your experience with me if you are skillful in this field? Any relative comments are also welcome. Thanks in advance.
Yiling
Old   March 17, 2003, 19:45
Default Re: How to solve equations from Penalty FEM in Flu
carlslack
Yiling,
You can optimize your Guassian elimination method by employing a skyline storage strategy. The idea is to trim all leading and trailing zero elements from each row of your system of equations. I've written an incompressible flow solver with Gaussian elimination, and this strategy results in an average reduction of 88% of storage space and computational effort.
-Carl
Old   March 20, 2003, 04:11
Anthony Wachs
Try to switch to iterative solver like preconditioned conjugate gradient (PCG) with sparse matrix storage as suggested in the previous mail.
PCG work fine for large matrix systems and combined with sparse storage you will save a great amount of memory.
Anthony
Old   March 20, 2003, 14:58
carlslack
I thought that PCG was only suitable for symmetric systems... What strategy to you use to apply it to the (non-symmetric) NS equations?
-CS
Old   March 25, 2003, 16:43
Yiling
Hi, Anthony I have tried the method of PCG, but still can't solve the equation. Firstly my PCG code has worked for general linear equation, and it does work even asymmetric equation. Secondly when I use this code for the equation generated from Penalty formulation, the convergent rate is very slow, if we set the tolerance as 1.e-4 at every point, it seems hopeless to reach that value. Another worry is: in the PCG algorithm, we have to involve the calculation of matrix by vector, while some entries in the nearly-singular matrix are very large in the order (1e+8), the result of multiplication of matrix by vector sometimes exceeds the range of real variables or even for the double precision variable.
Yiling
Lax-Wendroff solve hyperbolic equations zyf Main CFD Forum 0 July 14, 2003 04:53
FVM,FDM AND FEM d Main CFD Forum 4 May 30, 2003 03:19
How good is CFD? kai Main CFD Forum 39 April 7, 2000 12:48
Agglomeration multigrid to solve Euler equations Jian Xia Main CFD Forum 3 January 11, 2000 18:07
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
