Radiation Question
Old   March 26, 2003, 09:48
Default Radiation Question
Manosh
How to calculate 'scattering coefficient' in combustion gases? Any references and ideas are very much appreciated.
Manosh
Old   March 26, 2003, 16:00
Default Re: Radiation Question
Jeff Moder
If you are asking how to calculate the scattering coefficient for the gaseous species (not solid or liquid species), my answer is that this that scattering from a gas molecule is neglible (relative to gas-phase absorption or scattering by a solid particle, if present), so just use
scattering coefficient = 0
for all gaseous species
Old   March 27, 2003, 06:32
Manosh
Hi
Yes, I am asking how to calculate the scattering coefficient for the gaseous species. Can you please write me details 'why scattering from a gas molecule is neglible'?
If I dont know the scattering coefficient how do I compare this with absorption?
Any references please?
Regards
Manosh
Old   March 27, 2003, 11:08
Jeff Moder
Here is an example using some data from Siegel & Howell, Thermal Radiation Transfer, 2nd ed.
Let the medium be air at standard T and P (T=300 K and P = 101325 Pa)
The spectral blackbody emissive power has maximum value at
lambda_max = 2898 microns K / 300 K = 9.7 microns
T average scattering cross-section (s_lambda) versus wavelength for this case is shown in Fig 16-12, p.588 of Siegel & Howell for air and has approximately a 1/lambda^4 dependence (ie, Rayleigh scattering).
Let's assume the blackbody emissive power is significant in the range 0.2 to 100 microns (I just went a generous portion on each side of lambda_max).
The maximum s_lambda in this wavelength range is thus at 0.2 microns, which from data in Fig 16-12 is
s_lambda = 3.0e-25 cm^2 = 3.0e-29 m^2
The scattering coefficient sigma = s_lambda * n
where n = # particles/m^3 = P/(kT)
= 101325/(1.38e-23 * 300)
= 2.45e+25 particles/m^3
Thus, sigma = 3.0e-29 * 2.45e+25 = 7.35e-04 1/m
Optical thickness based on scattering only would be
tau = sigma * L
where L = some characteristic length of your problem
(maybe mean beam lenght)
For tau > some value, you could consider scattering important. I'll use the following criteria
tau > 0.01
which means you need a length L
L > 0.01/7.35e-04 = 14 meters
for scattering from air at standard conditions to have any significant effect on radiative intensity.
The above is just an order of magnitude example. Also, even if you had an L large enough for scattering to cause any significant change in the radiative intensity, if the absorption coefficient is much larger than the scattering coefficient, (say 100 times or more), you can still safely neglect scattering.
I imagine except for the case of a very large domain in which absorption is small that scattering due to gas molecules is neglible. (If you want to show why the sky is blue, okay you should not neglect scattering in your atmospheric simulation, but if you are trying to predict radiation source terms in your energy equation or radiative heat fluxes to your domain boundaries, I doubt you will encounter many situations in which gas-phase scattering is important).
Old   March 28, 2003, 05:22
Manosh
DEar Jeff
Thank you very much for your details discussion.
Manosh
Radiation Reunion STAR-CCM+ 1 October 16, 2011 11:38
Surface incident radiation Pipiola FLUENT 0 August 11, 2009 15:46
Problem: radiation / patches FAPSler STAR-CD 0 July 29, 2009 09:42
Radiation modelling Deeps CFX 2 September 7, 2007 10:12
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 05:56
