How to implement a fan curve in CFD
I am trying to model a fan/blower in my code. Could anyone provide me some guidance on how to incorporate a fan curve in a FEM code? Many Thanks! Steve |
Re: How to implement a fan curve in CFD
Your question is quite vague. Would you please clarify a bit further?
I was trying to create a model to simulate fan effects in flow fields for electronic cooling applications. Here the fan curve(pressure difference vs flow rate across the fan) is known.
Recently I have figured out this can be done by simply adding the pressure drop (given in the fan curve) into N-S equations as a force term. What's your opinion? Thanks! Steve |
Try to locate the PhD thesis of Dr M van Staden. He did a PhD specifically on this topic.
You can email him at: Martin.vanstaden@pbmr.co.za His PhD is about implementing fan curves for axial fans into a CFD code using momentum source terms. Great reading! |
