-   -   Need ODE solver (http://www.cfd-online.com/Forums/main/5953-need-ode-solver.html)
Levi April 6, 2003 08:35
Need ODE solver
Hi all, I am looking for an ODE solver for large systems (maybe stiff). The number of ordinary diff. equations is ~ 10^6. For solving we have a parallel cluster with 64 CPU. Does anyone know where to find such code? Thanks in advance.
Manan April 7, 2003 14:02
Re: Need ODE solver
Hi Levi
If you are working in fortran then u can use lsoda.f available on net. It employs Gears adaptive time step method used for stiff odes. Although C versions of the code is also available,I am not sure about its implementation.
Manan
Levi April 9, 2003 08:37
Re: Need ODE solver
Thank you, Manan. I know lsoda.f, lsode.f, etc codes and I use its for a long time. But all such codes are aimed at full matrixes. They contain long working arrays (~ 2*N^2). If N~10^6 it is obviously that there are not enough memory. I've very sparse matrix when only 7 elements from a million are non-zero in the each line. Are there any special solvers for such case?
Manan April 9, 2003 22:38
Re: Need ODE solver
Hi Levi,
lsoda solved my problem so i didnt look anywhere else.I know a group working in my deptt which uses ode solvers and are abreast with latest development in this field. If you want the contact just mail me and I can send it to u.
Manan
