Boundary Layer code
Old   April 15, 2003, 22:35
Default Boundary Layer code
ellen
Hi, I'm trying to find a boundary layer code using finite-difference or finite-volume method. Could anyone give me a reference to such codes? I'd appreciate it. thank you.
ellen
Old   April 16, 2003, 05:53
Default Re: Boundary Layer code
Manosh
If you like Keller-Box in BL then you can have a look the following book. It is using finite-difference. I think some of the source codes are also there.
Momentum transfer in boundary layers -- By Tuncer Cebeci, Peter Bradshaw.
Manosh
Old   April 16, 2003, 07:20
Praveen
The book "MOdeling and Computation and Boundary Layer FLows" by Cebeci contains a floppy with source codes.
Old   April 16, 2003, 12:23
ellen
Thank you guys. appreciate it.
ellen
Old   April 21, 2003, 17:11
BAK_FLOW
there are a couple of codes that I know of in addition to Cebeci's stuff:
1. GENMIX by Spalding that comes with a book and a fairly good description of the method.
2. EddyBL, or something like that that is distributed with Wilcox's "Turbulence Modeling for CFD"
3. Some very simple codes in the back of Schetz's book "Boundary Layer Analysis".
Have fun with them.
Regards,
BAK_FLOW
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
Searching for an unsteady boundary layer code Daniele Main CFD Forum 0 September 20, 2004 08:17
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
