to versi
Old   April 23, 2003, 03:01
Default to versi
Dario
Thank You for your fast response, but why should an iterative method converge if the matrix is completely random? it's not positive, not diagonal dominant and not symmetric... Does your code work always?
Old   April 23, 2003, 05:10
Default Re: to versi
versi
Not always converge. In most of my cases, due to central difference used for Laplace operator, diagonal dominat is available.
Old   April 23, 2003, 06:09
Dario
Maybe you use the elliptic grid generator as smoothing for a pre existing grid; in this case you should find coefficients for the elliptic equation that keep the dominance.
But could you tell mer something about the orthogonality?
Problem with IcoFoam in parallel skabilan OpenFOAM Running, Solving & CFD 12 April 1, 2008 05:55
Using compiled UDF:s in different Fluent versions S H FLUENT 1 September 12, 2007 03:40
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
Reaction Rate Databse A.S. Main CFD Forum 3 August 26, 2005 03:45
CADfix. Does anyone Know about Shareware Version? Kotrolos Ioannis Phoenics 3 November 18, 2001 10:18
