turbulence model question
Old   May 2, 2003, 12:11
Default turbulence model question
Jason Wei
Hi:
I believe there are a lot of turbulence model expert in this forum. May I ask two fundamental questions:
1) How can we determine if we should use turbulence model rather than only solving laminar problem? I know in heat transfer textbook we usually consider the Reynold number. But when we deal with complex geometry, it is hard to define characteristic dimension and no experimental data is available. In some special cases the flow has both external and internal characteristics, how can we choose the critical Re number?
2) As I understand, we should only implement the Algebraic mixing-length turbulence model in the boundary layer. But if the free stream is inside an large enclosure and still have some transverse velocity gradient, should we also add the turbulence viscosity and diffusivity to the whole domain or we just leave it as laminar?
Thank you very much for you time and help.
Old   May 6, 2003, 01:45
Default simple question cannot be simply answered
Jason Wei
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 03:08
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 06:15
Implementing and running a new turbulence model svens OpenFOAM 3 August 21, 2009 03:59
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
