May 30, 2003, 03:43 |
LES in Turbulence
Hi Friends
These days I'm studing the Large Eddy simulations for Turbulence. Why we want to introduce the filtered velocity for LES? and why we filtered Navier-Stokes equation for the LES? Thank you Ranga |
May 30, 2003, 06:13 |
Re: LES in Turbulence
In LES, you must need to use a filter (there are some different types of filters in literature) to seperate large eddies which you will simulate directly from the small eddies which you will model.
Just think a filter is like a net, using this you will catch big fishes (wavenumber < cut off wavenumber) and drop small fishes (wavenumber > cut off wavenumber). Hope this helps. Manosh |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Naive question about turbulence and LES | Renato | Main CFD Forum | 1 | October 4, 2005 23:01 |
