compressor simulation
I am looking for some literature on compressor simulation. can someone refer some papers or something.
thanks |
Re: compressor simulation
Axial or radial?
A few refernces to name with are :
See Jan 2002 J. of Turbomachines 1991 J.of Fluid Engg. paper by B. Lakshminarayana (Freeman Schoolar Lect.) Search for papers by C. Hah, W.N. Dawes, J.D. Denton, Admzayck, There is a vo-Karman Lect Series on it, LS 1996-05 if I am not mistaken and IMechE Part A Journal of Power and Energy vol 215, No 6. |
its centirugal compressor
NASA has some of the classic test cases. Go to http://gltrs.grc.nasa.gov/ then follow the link to "Keyword searching and retrieval of NASA Glenn technical reports". Once here I would suggest 2 searches. First, search on "LSCC", which stands for Low-Speed Centrifugal Compressor. This is a well documented (both experimental and numerical) research compressor and seems to be used as a classic benchmark in university as well as commercial codes. Second, search on "centrifugal AND compressor". Other cases will come up, including a high pressure (4:1) case with geometric coordinates provided.
