June 4, 2003, 12:01 |
tube-in-tube
Hi all, im brand new to CFD. Im trying to model a tube-in-tube heat exchanger using fluent 6.1. The tube is very long and then with fully turbulent flow. Can anyone give some insight as to what kind of turbulent model, mesh and wall treatment to use?
thanks alot Andrew |
June 4, 2003, 12:23 |
Re: tube-in-tube
Do you want to simulate heat transfer too and also conjugate heat transfer.
June 4, 2003, 13:59 |
Re: tube-in-tube
yes. one tube has air entering at 400k and the other, air at 1300k
June 4, 2003, 15:53 |
Re: tube-in-tube
In case of conjugate heat transfer ..., remember never to use k-epsilon turbulence model, it overpredicts the heat transfer. As you are using Fluent, you can specify velocity directly as inlet condition, outlet you can specify as pressure-outlet. As far as turbulence intensity and length scale are concerned you can use corelations given in Varstegee and Malansekara (hope I have spelled it correctly) for pipe turbulent length scale. I hope with this you can solve your problem.
Regards Apurva |
Display Modes | |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 03:10 |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 06:55 |
Tube inside a tube simulation | Rashmichem | Main CFD Forum | 0 | December 14, 2010 02:52 |
BC at the inlet of a tube | Jackie | Main CFD Forum | 11 | July 29, 2003 12:57 |
Draft tube and MFR/SG | nyatoto | CFX | 0 | June 3, 2003 06:55 |
