June 14, 2003, 20:33 |
Velocity Inlet BC..!!
Hi all, Is it possible to specify the velocity at the inlet. I'm solving RANS. Cheers
June 16, 2003, 11:44 |
Re: Velocity Inlet BC..!!
what for? boundary layer? jet? compressor? supersonic? subsonic? |
June 16, 2003, 15:02 |
it is definitely possible and that is all that's needed for incompressible laminar flow. Depending on your turbulence model, you may need to specify additional parameters.
June 17, 2003, 04:51 |
Hi, Jim & Ted
Jim, The case is subsonic inlet.. Ted, I@m talking about compressible BL. Looking for more discussions. Thanks. Jim |
June 17, 2003, 04:53 |
To add more,If I specify the velocity at the inlet what property to extrapolate from interior of the domain?.what to specify beside the velocity at the inlet?.
Velocity Inlet BC -- Flow Reversal | salihovic | FLUENT | 0 | May 8, 2011 05:45 |
Changing Boundary: Decreasing Inlet Velocity - Convergence Issues | VT_Bromley | FLUENT | 3 | February 12, 2011 09:02 |
User Defined Profiles, Swirl, Velocity Inlet | saurus | FLUENT | 0 | January 26, 2011 15:35 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
