-   -   eddy viscosity distributions in the wake? (http://www.cfd-online.com/Forums/main/6287-eddy-viscosity-distributions-wake.html)
zqnwpu June 25, 2003 22:22
Is there a gap for eddy viscosity distribution in the wake ? when i use structure c grids,there is.but my classimate using unstructured grids got a no-gap result,why?
kei-tee June 26, 2003 09:38
Re: eddy viscosity distributions in the wake?
wake of C grids is singular line. Usually, we use wake line BC as averaged value of nearest grid points. ie. suppose wake line are j=1,jmax,
q(1)=q(jmax)=0.5*(q(2)+q(jmax-1))
best regards
kei-tee
zqnwpu June 27, 2003 03:53
Thank you very much. I just do as you said .but there is a gap in the wake ,I don't know whether it is right.
kei-tee June 29, 2003 04:12
What kind of Turbulence model do you use? Some model needs special treatment for wake BC.
zqnwpu July 1, 2003 00:26
i use k-epsilon,k-omeg & other use spalart.
kei-tee July 1, 2003 09:47
S-A needs wall distance. In wake region, you should take the value as large value (ex. 1.0E6).
I don't know for k-eps & k-omega.
As long as you impose averaged value on Q vector & eddy viscosity in wake region, there is not a gap, I think.
