-   -   Labyrinth seal test cases (http://www.cfd-online.com/Forums/main/6330-labyrinth-seal-test-cases.html)
BeachComber July 7, 2003 15:02
Looking for good labyrinth seal test cases (leakage flow rate, pressure drop, etc.) to compare with calculated results. Thank you in advance for any input.
Stas July 8, 2003 04:21
Re: Labyrinth seal test cases
Hi, There is USSR prescribed algorithm for standard labyrinth seals design. I used it and got very good prediction of flow rates.
Stanislav
BeachComber July 8, 2003 16:28
Stanislav - thanks for your comment. Would you be able to provide more information, for example, where to find this algorithm? Thanks in advance.
Stas July 9, 2003 03:28
It is РТМ 108.020.33-86 «я лабиринтные стационарных паровых и газовых турбин и компрессоров. Проектирование и расчет» in English - 'Labyrinth seals for fixed steam and gas turbines and compressors. Design and calculations.
I have hard copy of Russian text(I think it was newer translated or put on Internet)
I you need more information I'll help.
Stanislav
PS - I'm in Ukrainian, city Kharkov, were are you from? You can write to my e-mail - STAS at UA dot SOFTINWAY dot COM
Regards,
sanandtv August 15, 2010 04:35
Hi Stanislav
i am in need of a means of designing labyrinth seals for gas turbine applications.
can you help me on this?
thanks in advance..
sanand t v
India
