mesh size and convergence
Old   April 3, 2009, 13:34
Default mesh size and convergence
Ertan Karaismail
ertan is on a distinguished road
Hi all,
I am running an unsteady simulation (in FLUENT) of airflow for a HVAC project. The flow is turbulent and I am using SST k-w turbulence model. Time and spatial discretizations are all 2nd order. Solver is implicit. Time step is 0.001s. The grid I am using can be considered as coarse.
The problem is that the solution (especially continuity) is converging so slowly even though I played aroung the URF of momentum and pressure. I am wondering if grid is the only problem here. Do you have any ideas to share?
Thanks.
Ertan
ertan is offline   Reply With Quote
Old   April 3, 2009, 15:54
N/A
harishg is on a distinguished road
Do you employ the SIMPLE algorithm ? You might need to change your under relaxation factors in that case. Do you employ multigrid for your pressure solver ?
harishg is offline   Reply With Quote
Old   April 3, 2009, 16:15
Ertan Karaismail
I have tried both SIMPLEC and PISO. Fluent uses multigrid scheme for pressure (at least for the current settings). Is it worth to switch to SIMPLE? Decreasing the URF didn't help much. Still it takes about 150 iteration per time step.
Mesh size and solver residuals... Scott CFX 5 December 15, 2008 17:10
How to decide the mesh size? echo Siemens 1 May 23, 2006 05:34
Convergence problems with different mesh size echo Siemens 10 April 19, 2006 04:13
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
What should be the correct size of mesh rajeev FLUENT 5 August 14, 2001 17:44
