pressure
Old   July 14, 2003, 09:46
Default pressure
Roy
Consider 2 concentric cylinders rotating with w1 and w2 in the same direction. Between does 2 cylinders there is an incompressible viscid fluid. Why is the pressure gradient a function on the radius, and not the angle (the flow is induced by the rotation and in the rotation (teta) direction)?
Tanx.
Old   July 14, 2003, 13:46
Default Re: pressure
ag
If the flow is steady, then think about what you are asking - a pressure gradient in the circumferential direction would imply that the pressure at zero degrees around the cylinder would be different than the pressure at 360 degrees around the cylinder. But that would make no sense, unless you have some mechanism to arbitrarily insert discontinuities in the flow.
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 14 March 8, 2011 09:19
Using pressure outlet BC Shreyansh FLUENT 0 November 5, 2010 15:57
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
Setting pressure and velocity in inlet Asghari FLUENT 5 September 22, 2006 13:23
