April 12, 2009, 19:32 |
Liquidius and solidius temperatutrure
Saima
Rep Power: 16 |
Hi ,
I have a problem in which a heater is on leading edge of an airfoil and this airfoil is placed in Icing wind tunnel. Air is inside the tunnel at -5C. And water spray by using atomizer is also there. I have to figure out what will be the temperature of airfoil at different places. Could you tell me which model should i use? Currently i am using (solidification+VOF). I want to know what is the liquidus and solidius temp in this situation? It is very urgent. Many Many thanks in advance. Regards, Saima |
April 13, 2009, 13:13 |
SJ
Rep Power: 17 |
liquidus (melting) and solidus(solidification) is the term used for alloys which represents the start and end of mushy zone. water i guess should be modeled as pure susbstance so the melting and the solidification temperature should be same. Please read some standard thermodynamics textbook
April 13, 2009, 13:25 |
Saima
Rep Power: 16 |
So u mean its 273k or 0C for both.
Thank u so much i was also thinking that but i was not sure. Thanks alot. Saima |
