'IMPINGING JET' Heat Transfer
Old   March 14, 1999, 15:51
Default 'IMPINGING JET' Heat Transfer
Amir Omoumi
Hello everybody;
For my thesis I'm working on modeling the heat transfer of Impinging Jets by 2-equations Turbulence models (nonlinear boussinesque). I really appreciate any suggestions for Boundry conditions, available or successfully used Codes or any other resources regarding this matter. Thank you in advance.
Old   March 14, 1999, 20:31
Default Re: 'IMPINGING JET' Heat Transfer
Duane Baker
There was a code validation problem which was done at the Canadian CFD Society meeting CFD95 which was lead by Andrew Pollard. Unfortunatly, the results were not published in the Poceedings...so I do not have them...but check out the page:
http://www.acs.ucalgary.ca/~bauwens/cfd_sc/maineng.html Pollards Email is on there too so you may want to contact him.
Good luck.....................................Duane
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Impinging Jet Heat Transfer Dan Laurin CFX 5 July 13, 2006 08:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
IMPINGING JET ........... HELP!!!!!!!! Amir Omoumi Main CFD Forum 10 August 30, 1999 22:11
