Y plus
Old   April 18, 2009, 16:44
Default Y plus
abdul
abdul is on a distinguished road
I am using different discretization schemes in Fluent to predict accurate results, discretisation schemes such as PRESTO for Pressure, second order upwind for Continuity etc etc
different discretisation schemes for the same 3d model, however when i refine the Yplus values to a certain limit and reducing it so there are 0 cells to refine, the amount of cells that are being refined vary accordingly to the different schemes, does anyone know why?
surely they should be the same amount of cells refined?
abdul is offline   Reply With Quote
Old   April 20, 2009, 08:45
Aroon
vishyaroon is on a distinguished road
Your y+ values are based on the wall shear stresses. These are going to be as different as the near wall stresses predicted by the schemes you use. So in short you may not end up with the same y+ using different schemes. This is why you observe that you may have to refine your grids over and over again.
Another thing I'd point out is even after you refine the grid, your solution is going to be different from what you had using the coarser grid. Hence you'll again have different y+ values.
vishyaroon is offline   Reply With Quote
Thread Tools
Trackbacks are On
