Different between ACIS, PARASOLID, IGES, STEP
Old   July 26, 2003, 12:44
Default Different between ACIS, PARASOLID, IGES, STEP
Jos
Do anybody know what is the different between the file format of ACIS, PARASOLID, IGES and STEP? Any website can provide me the information of file format above. I appreciate any suggestive opinions. Thanks.
Old   July 31, 2003, 20:27
Default Re: Different between ACIS, PARASOLID, IGES, STEP
John Chawner
ACIS is the name of a geometry library from Spatial Corp., which is owned by Dassault Systemes, the CATIA people. An ACIS file, usually called an ACIS .SAT file, contains geometry in their native format. I suggest you try www.spatial.com.
Parasolid is the name of a geometry library from EDS, the Unigraphics people. A Parasolid file, usually called a Parasolid X_T file, contains geometry in their native format. I suggest you try www.parasolid.com.
IGES is an acronym for Initial Graphics Exchange Specification, a standardized file format for exchanging CAD data. The web site www.nist.gov/iges has a lot of information about IGES.
STEP is an acronym for STandard for the Exchange of Product model data, an ISO standard (10303) for exchanging CAD data. It is newer than IGES. This web site is as good as any to begin your search: http://cic.nist.gov/plantstep/stepinfo/step_def.htm
I hope this helps.
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
CADDS5 -> IGES, STEP or Parasolid James Date Main CFD Forum 0 September 3, 2004 14:42
