Two-phase/ Single phase mix flow
Old   August 5, 2003, 16:06
Default Two-phase/ Single phase mix flow
Reza
I have been told that for the case of two phase/single phase mixed flow there is always problem with the numerical treatment of the fluxes at the interface. I have used the upwind scheme and have problems for the two phase/single phase interface (where we have phase change from single phase to two phase, such as using the flash calculation). Did anyone had the same time of problem in the past and if so how did you managed to solve it?
Old   August 6, 2003, 06:36
Default Re: Two-phase/ Single phase mix flow
id
have you thought of solving Riemann problem from which you can use upwind schemes !
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 16:31
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
low speed compressible two phase flow?? cat CFX 0 November 15, 2005 07:59
