May 5, 2009, 23:05 |
REy < 200
Rep Power: 16 |
In an analysis of turbulent flow, k - e model was used with enhanced wall treatment. The following requirements are necessary for enhanced wall treatment: 1) y+ value to be of the order of 1 and 2) atleast 10 cells within viscosity affected near wall region(Re y < 200) I have checked for y+ and the requirement is satisfied. But I am unable to check for the 2nd requirement. How do I find the distance from the wall where Rey < 200 ? Does it involve manual computation or can it be done in Fluent? |
May 5, 2009, 23:58 |
Aroon
Rep Power: 17 |
I am not sure if there is a function to look for Re y < 200. If you know that the first mesh point is < 1, try defining a variable that specifies Re y. Plotting this parameter will show you as to how many points are within Re y < 200.
Tubrogrid - Error on cut-off at TE | Flavio | CFX | 5 | January 12, 2017 09:41 |
Single v.s. double precision | Confused | CFX | 15 | November 10, 2016 04:42 |
low rey Naca 0012 | Ravi | FLUENT | 5 | September 26, 2006 15:34 |
increment in volume fraction after 200 time steps | Rashmi | FLUENT | 3 | May 22, 2006 00:22 |
200 data files to post process (how?) | Mark R | FLUENT | 1 | August 9, 2001 13:35 |
