flow resistance of cylinder in parallel flow
Hi!
I am looking for literature data for the flow resistance (and heat transfer) of a number of parallel aligned finite length cylinder in turbulent axial flow. It is something like a rod bundle. I need the resistance of the inflow (around the top surfaces), the parallel flow and the outflow (around the back surface). Thank you!! Ralf gas flow . . . . V =>... Length L => ________ => I________I ...... Diameter D => => ________....... Distance A => I________I => => ________ => I________I => => ________ => I________I => |
Have a look in Zukauskas book "Tube Banks in Crossflow" or in his chapter in "Advances in Heat Transfer" 1987.
1 Attachment(s)
Hi!
as i understood, this is about cylinder in cross flow. But i need data for cylinder(s) in axial flow! Especially for a larger number of them (something like 100-500), aligned axis-parallel, depending on the cylinder diameter, the length and the distance between them. The data should include the edges of the cylinder... Thanks.. Ralf |
Sorry, I missed the point that the flow is parallel to the cylinders...
