August 12, 2003, 12:23 |
Engine combustion related question
I'm doing my Ph.D in " two stroke diesel engines with spark plug for efficient combustion'.
Is it possible to burn diesel by Injecting at lower pressure and igniting with spark plug |
August 12, 2003, 17:29 |
Re: Engine combustion related question
It is possible, but it may or may not be desirable. The efficiency of an ordinary diesel engine is partly due to its high compression ratio, so you will lose efficiency if you lower the combustion pressure. It would be surprising if there were not already some literature on this topic. SAE Transactions would be a good place to start looking.
analysis of internal combustion engine induction | TOM | FLUENT | 5 | August 29, 2011 05:20 |
question about modeling combustion | xinhui zhang | FLUENT | 1 | December 16, 2007 19:40 |
combustion in low heat rejection engine | M.MANI | Siemens | 0 | March 18, 2006 04:27 |
Using Fluent6.1 to model engine combustion | Allanhill | FLUENT | 1 | June 15, 2003 04:36 |
Question concerning about the flow simulation of a fan in an engine room. | ghlee | Main CFD Forum | 3 | October 21, 1998 07:05 |
