A problem about initialization
Old   May 19, 2009, 23:19
Default A problem about initialization
zhangyuan
zhangyuan is on a distinguished road
Hi,everyone
I need your help, I have a problem in modeling the steady gasification of coal water slurry. The inlet pressure of the oxidizer is 8.1Mpa, and the mass flow rate of the oxdizer is 15.72kg/s, and the velocity is 55m/s. But if the velocity is defined as the boundary condition of the inlet and initialized, the mass flow rate of the oxidizer is 129kg/s in the result of my simulation, more than 15.72kg/s. And if the mass flow rate is defined as the boundary condition of the inlet and initialized, the velocity of the oxideser is 2.88kg/s, less than 55m/s. I want to know why? I try it again and again, but get the same result. Can anyone help me? Thank you!
zhangyuan is offline   Reply With Quote
Old   May 20, 2009, 01:17
N/A
harishg is on a distinguished road
I do not have much knowledge about multiphase flows but seems you have some problems with the specific model that you employ for your computations to obtain such a vast difference in the predictions. Where do you get your parameters from ? Also are you sure you the models that you employ has shown to produce good results for the gasification studies ?
harishg is offline   Reply With Quote
Old   May 20, 2009, 03:26
zhangyuan
Thank you
I read many articles about simulation of the gasifier of the coal water slurry, and they are similar with what I am doing. So I use the same models as them. Non-premixed combustion model is used to simulate the chemical reactions and DPM model is used to simulate the paticle phase in my simulation. I am sure of them.
The parameters what I am using in my simulation are from the industry.
Thread Tools
Trackbacks are On
Initialization problem when using Axisymmetry BC Eduardo FLUENT 0 August 4, 2008 09:23
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
coal combustion initialization problem Chetan Prahsant CFX 1 May 1, 2007 05:41
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
