ENO, TVD, QUICK...
Old   August 20, 2003, 15:15
Default ENO, TVD, QUICK...
I was wondering...
Why would someone use QUICK, TVD, ENO, etc for the linear advection equation. Why is ENO considered best, TVD next and finally QUICK? How is this know mathematically...or is it based on empirical ( results from simulation etc) data?
Old   August 21, 2003, 09:45
Default Re: ENO, TVD, QUICK...
alex
For sufficiently small values of "viscosity", the linear advection equation evidences a sharp gradient in its solution, the occurence often present in real-life problems. If you do not pack a large (very large) number of nodes inside of this high gradient area, and use a "non-optimized" fe, fd or fv discretization technique (QUICK for example) your solution will be polluted by dispersion errors (you'll see oscillations) signaling the inability of the mesh to resolve the sharp gradient (in many codes this is masked by adding artificial diffusion, which comes in all kinds of shapes and forms). Using a large number of nodes gets expensive in 3D and the location of the gradient region in not necessarily known in advance. TVD, ENO, WENO, compact difference fd, optimal h-p fe, tws fe just to name a few are designed in an attempt to eliminate dispersive errors in the numerical solution without introducing excess diffusion in the process.
Nvd / tvd MichiB OpenFOAM Programming & Development 8 July 21, 2021 05:27
Problemas with Quick titio OpenFOAM Running, Solving & CFD 4 May 12, 2010 06:09
TVD and ENO Ferreira Main CFD Forum 1 March 4, 2008 07:01
TVD ... Questioner Main CFD Forum 1 June 7, 2006 08:54
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
