Fluent residual problem?
Old   August 25, 2003, 07:41
Default Fluent residual problem?
prasat
I have problem in which I chose to take residual to be continuity 1.0e-06 x-veloc 1.0e-06 y-veloc 1.0e-06. But after running for more than 3000 iteration my solution is not converged. although my residual value for x and y velocity is leass than 1.0e-06. I want to know what should be the next step for me. Please help
Old   August 25, 2003, 10:19
Default Re: Fluent residual problem?
Andy
Firstly, I would suggest that you post on the specific Fluent forum, as you may get code specific help there. However, if I understand your question although I am not sure I do, it is not wise to monitor convergence based just on the level of your residual, you should check other parameters in your solution. You have not really given enough information for anybody to be more specific, I would suggest doing so in the Fluent forum.
Andy
Thread Tools
Trackbacks are On
Forces in OF15 richard OpenFOAM Running, Solving & CFD 167 June 18, 2016 06:04
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
