Naturla convection in enclosed cavities
Old   May 30, 2009, 13:56
Default Naturla convection in enclosed cavities
Ramazan
Karek is on a distinguished road
Please help me urgently !
I have an article to solve in FLUENT program.Problem is that all the equations in article are in dimensionless form.There are no any definite parameters (temp,dimensions,etc).
In article Ra varies between 10^2 to 10^6.Question is What parameter can I change to reach 10^2 to 10^6 in fluent.Temperature difference or ?
Karek is offline   Reply With Quote
Old   May 30, 2009, 17:35
Ahmed
Ahmed is on a distinguished road
That is definitly a very short description, here is a short answer, write down the definition of the Rayleigh number, What could you change? temperature, Beta, nu, alpha or may be the gravity if you are working in the outer space/ high altitude. Who knows, it is up to you
Good Luck
Ahmed is offline   Reply With Quote
Old   June 1, 2009, 16:38
Default Natural convection in cavities-SOLUTION CONTROL
Ramazan
Please give me an idea ;
In Fluent program there is a solution controls menu and I want to enter solution types for pressure ,momentum and energy equations.
In article which I try to solve in fluent had given some information about this subject.But it is not clear.
Please look at following part tell me the solution controls for pressure ,momentum and energy equations:
[IMG]file:
2.2.5. Solution procedure
The governing equations, Eqs. (1)(4), are discretized by the fi-
nite volume method (FVM) on non-uniform grid system [34]. The
third-order QUICK scheme and the second-order central difference
scheme are, respectively, implemented for the convection and diffusion
terms. The set of discretized equations for each variable are
solved by a line-by-line procedure, combining the tri-diagonal matrix
algorithm (TDMA) with the successive over-relaxation iteration
(SOR) method. The coupling between velocity and pressure
is solved by SIMPLE algorithm [34]. The solution is terminated until
the convergence criterion is reached, i.e., the maximal residual of
all the governing equations is less than 10^6.
Old   June 1, 2009, 18:46
Ahmed
[IMG]file:
If you are looking for recommendations from the readers of this forum, then you need to start learning the basics of communications.
What recommendations do you expect if you do not explain the problem?
Do you think the readers are sitting by your side and know what you are solving? or do you believe all cavities are the same?
Attach the paper you are talking about, or give an address where we can read it or explain the problem
Old   June 2, 2009, 06:20
Default Natural convection in square cavities
Ramazan
Dear Ahmed,
Thank you for help file link is here ;
http://rapidshare.com/files/239914181/ANA_ALI__350_MA.pdf.html
I try to solve this article with FLUENT.I know the basic rules of this program and I always search the all the subjects which are related with this article before writing.But really ,these problems which I already wrote need help.
Please look at my article and give me an idea for my questions.(1.Question :Rayleigh number and 2.Question :solution controls menu )
Old   June 19, 2009, 16:18
Default Nu number calculation in Fluent
Ramazan
Hi all!
My study is related with 2D natural convection in a square cavity.I change the location and length of the heat sink-sourse pairs to see flow structure in cavity.
I solved in Fluent program, but I dont know where can I obtain surface Nu and average Nu numbers.Is there any command to calculate average and local Nu number in Fluent.
Thread Tools
Trackbacks are On
natural convection air in cavities with k-eps tommy CFX 0 September 30, 2008 08:48
Natural convection cavities high rayleigh numbers tommy CFX 3 September 27, 2008 15:43
Coupled vs Seg - Natural vs. Forced Convection Alex CD-adapco 5 December 12, 2007 05:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 20:43
Instability at the onset of natural convection Magherbi Main CFD Forum 0 October 23, 2002 09:53
