Proper orthogonal decomposition of turbulent flow with k-e
Old   June 5, 2009, 09:32
Default Proper orthogonal decomposition of turbulent flow with k-e
Blob is on a distinguished road
Hi. Is anyone familar with performing a proper orthogonal decomposition/Galerkin projection of the k-e turbulence model? I'm doing a practice run of the method using cavity convection (buoyancy-driven flow) at the moment. The laminar version works well, but not at all with the turbulent counterpart. What are the caveats involved in projecting the k-e model? For example, I'm not sure how the wall function comes in play into this. Do I even need to consider it in the projection since the wall function only affects a couple of nodes at the boundary? I would be interested in getting anyone's insight on the difficulties associated with reducing the k-e model. Thanks!
Blob is offline   Reply With Quote
decomposition, k-e, proper orthogonal, turbulence
Validation case for turbulent flow Ratan Main CFD Forum 0 October 4, 2005 03:03
Is DNS the final solution of turbulent flow ? Li Yang Main CFD Forum 8 September 15, 2003 05:22
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
turbulent flow using PHOENICS Abdul Hafid Main CFD Forum 5 November 3, 1998 11:25
