what approach for direct mixing fluids with heat transfer and phase change?
Old   June 9, 2009, 15:44
Default what approach for direct mixing fluids with heat transfer and phase change?
henry clarke
hennas is on a distinguished road
I am trying to model the injection of one fluid into another and the heat exchange that follows. The process is complicated by:
1) a large initial temperature difference between the injected (cold) fluid and pool (hot) fluid - so considerable heat transfer.
2) phase change (boiling) of the injected fluid, creating a vapor phase.
3) injection occurs into a small chamber - so a large part of the breakup of the fluid is due to collision with the opposite wall.
4) the process is compressible and unsteady.
Now I am aware that this is an extremely complex problem, and I am unsure about what direction to take ie. whether to be looking at models that track the interface or, if this is not viable to be looking at particle type models.
If anyone is able to give me general or specific advice this problem, or what codes may flexible enough to solve it (openFOAM?, FLUENT?) I would be most grateful.
Thanks
hennas is offline   Reply With Quote
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 01:49
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
Which Code is Best for Two Phase, Heat Transfer earlc Main CFD Forum 0 September 23, 2005 20:26
Heat transfer coefficient for dispersed phase Julie Siemens 4 October 30, 2004 14:26
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
