the pole singulatity of cylindrical coordinate
Old   September 5, 2003, 21:05
Default the pole singulatity of cylindrical coordinate
Baolin Tian
Hello, everyone I am solving the Euler equations in cylindrical coordinate. The initial problem is the an imploding shock wave heading for the origin. However,when the shock arrive the origin,the computation can continue due to the singularity of pole. I have looked up some references, but I have not get a good answer, especially for the strong shock waves. I wish that someone could give me some proposals. thanks a lot!
Old   September 6, 2003, 01:44
Default Re: the pole singulatity of cylindrical coordinate
Praveen
Check out these references:
# Numerical treatment of polar coordinate singlularities. J Comput. Phys. V.157, 789-795
# Numercial treatment of cylindrical coordinate centerline singularities, IJCFD, 2001, Vol 15, 251-263
Old   September 6, 2003, 01:59
Baolin Tian
thanks a lot. In fact, I had checked out the two references listed above and other ones. But I still can't get the solution.
Old   September 11, 2003, 04:49
versi
Method 1: for ideal gas, use Guderlay (see Landau & Lifshitz classic Fluid Mechanics) self-similarity solution as asympotic solutin on 3-5 grid points near the pole . Method 2: (finitie volume layout). The first grid point is half-grid size away from the pole. Use reflection symmetry condition whenever needed.
Old   September 11, 2003, 08:55
Severn.
Do you (anyone) have a reference for the 2nd technique...that for Finite Volume?
Thank you.
Old   September 11, 2003, 09:17
Baolin Tian
thanks! I would like to to adapt the first method, for my numerical method is based on the difference method.
In my pesent method, I used a symmetrical boundary condtition for pressure, density and other scalar variables, and antisymmetric boundary condition for velocity accross the pole. And the first grid point was set the half step distance from the pole. This method is feasible the weak imploding shock waves or not very large contact discontinuities, but failed the strong ones. So I want to find a better solution method for the pole singularities.
Old   September 11, 2003, 10:13
Jim Park
During the 90's, I used (for different tasks) CFX-4, Fluent, and Flow-3d. The general problem of the polar singularity was treated the same by each - at least in the training sessions.
The recommendation was to abandon the cylindrical system and use block-structured boundary-fitted meshes in the Cartesian formulation. For Flow-3d, the recommendation was to use the FAVOR feature. Either of these approaches removes the singularity completely.
The reason for choosing a cylindrical system is usually because one or more of the boundaries is circular. Using the recommended approach, the boundary is accomodated without using a cylindrical coordinate system.
I don't know what the trainers for those three codes would recommend today. And I don't know what advanced features the codes may have today. But the marketing guys for the codes could certainly tell you!
Can openfoam solve problems in cylindrical and spherical coordinate systems? GGerber OpenFOAM Running, Solving & CFD 6 February 5, 2015 10:37
cylindrical coordinate vs cartesian coordinate Lam FLUENT 10 May 11, 2013 13:05
cylindrical coordinate -Gambit noussa ANSYS Meshing & Geometry 2 June 12, 2010 09:07
CFD Software with Cylindrical and Spherical Coordinate cfd2010 Main CFD Forum 0 June 9, 2010 21:55
Cording Ground.for in Cylindrical coordinate J.H. Lee. Phoenics 2 March 28, 2003 04:28
