July 6, 2009, 14:25 |
K-omega for flow in branches?
afm
Rep Power: 16 |
hello;
i'm trying to find the best turbulence model to be used for flow in branches and manifolds. using some data i found that standars and SST K-OMEGA is the best. is this ok? as i understand, k-w is only used for heat transfer applications. So, is it ok to use it for flow in branches? thank you |
July 6, 2009, 21:35 |
N/A
Rep Power: 17 |
There is nothing like a best RANS model for a particular problem. Some models perform better than the other. Regarding k-omega model, it has been applied for a wide range of flows. You can choose either the SST model or the most recent k-omega model of Wilcox for your application. Also integrate through the viscous layer with damping if you might encounter flow separation.
Specific Dissipation Rate (Omega) | Lourival | FLUENT | 2 | July 25, 2010 08:59 |
Definition of omega | jpo | FLUENT | 4 | April 7, 2009 15:06 |
Values of k and omega at the wall | oldah | FLUENT | 2 | February 22, 2008 03:08 |
Airfoil with k Omega | hoochie | OpenFOAM Running, Solving & CFD | 0 | July 3, 2007 08:10 |
Defining deformable mesh UDF to set omega | Chris | FLUENT | 0 | August 30, 2006 16:01 |
