September 24, 2003, 07:02 |
Shock tube problem
Hi, I have what would be considered a very basic question. I am dealing with a relativistic blast wave explosion problem, that is described by the relativitsic hydrodynamic equations in one dimension. The computational region is split up into two states initially with higher pressure and density on the left and a lower pressure and density on the right. The velocity is zero on both sides. At t>0 obviously the fluid from the higher pressure region on the left flows into the lower pressure region on the right. This is exactly like the classical Sod Shock tube problem. Is there an expression to initate the flow and give a fluid velocity v>0? Other wise the finite differnece scheme that I am using just gives a zero velocity everywhere? Or am i missing something?
P.S. As you may ahve guessed I am very new to the field of computational fluid dynamics!! |
September 24, 2003, 07:41 |
Re: Shock tube problem
read the numerical results of chapter 4 of this book;
Riemann Solvers and Numerical Methods for Fluid Dynamics. Toro E F (1999). Springer-Verlag. Second Edition, June 1999, 624 pages. -- |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
analytical solution of 1D shock tube problem | ma | Main CFD Forum | 10 | May 11, 2015 05:20 |
Shock tube simulation | harish | FLUENT | 5 | January 25, 2014 02:20 |
using ghost fluid method in shock tube problem | Amir | Main CFD Forum | 4 | February 24, 2011 10:09 |
Need a report on multiplestage shock tube | Yoo | Main CFD Forum | 0 | March 24, 2006 11:24 |
