May 24, 2008, 03:49 |
PhD dilemma
Hi
I have written a code that is very slow to run. I am considering whether or not to start all over again using other source codes (ie numerica by Toro) or contact the authors of the paper whose method I am trying to implement and asks them nicely for the source code. The paper was published back in 1990 so I am hoping they'll be generous enough to share it. Your advice is greatly appreciated. Shuo |
May 24, 2008, 04:30 |
Re: PhD dilemma
You can do well. Do not give up. I also suffered from such failure but recovered soon. Check the line-by-line. You can find bugs you has not realized. If not, you can ask someone else around you. I hope you feel better.
May 24, 2008, 16:34 |
Re: PhD dilemma
can you tell us what is that paper please ?
May 24, 2008, 20:26 |
Re: PhD dilemma
The paper is "Numerical analysis of gas-particle two-phase flows", R.Ishii, Y.Umeda and M.Yuhi, JFM 203:475-515, 1989. I tried to find the author in the web but hasn't been successful in tracking them down.
May 25, 2008, 03:53 |
Re: PhD dilemma
I strongly suggest you to think of numerica by Toro and to read his book. Also you need to think of having well established mathematical analysis for your case i.e. as in his book (chap 4 - 14). I used the same methodology for compressible two-phase flows.
Please let us know how it goes! |
May 25, 2008, 08:25 |
Re: PhD dilemma
Hi rieman
Can you recommend some papers on extending Riemann and upwind solver to multi-phase flows? Also how easy it to extend the methods outlined in Toro's book to the Navier-Stokes equations? I am simulating a supersonic impinging jet and viscosity would play a part for the wall jets. Cheers shuo |
May 29, 2008, 23:44 |
Re: PhD dilemma
Writing a code sometimes may give you a real hassle. Debug your code smartly; meaning check by running them section by section (part by part) in order to figure our which routine actually causes the bottleneck. Anologuous to experimental research, we try to reduce the number of variables at a time just to find out what is the effect of a single variable.
July 7, 2009, 19:13 |
Nishant Kumar
Rep Power: 16 |
Are there any possibilities to get the NUMERICA code from somewhere? |
July 8, 2009, 10:55 |
#9 |
Cangel W.Tan
Hey, just send an E-mail to Prof. Toro or send an E-mail to me, and I will give you the NUMERICA codes.
July 8, 2009, 14:35 |
#10 |
Nishant Kumar
Rep Power: 16 |
My email address is babuu.nishu@gmail.com Please send me the codes along with the documentation Thanks Nishant |
Display Modes | |
PhD subject | TheBearJew | Main CFD Forum | 1 | May 5, 2011 20:53 |
PhD in China (part 2) | Rui | Main CFD Forum | 9 | June 9, 2007 09:40 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
PhD Positions Available Nano and MicroSystem Fluid Dynamics using OpenFOAM | lynne | OpenFOAM | 0 | March 8, 2006 10:54 |
Possible to do online PHD/ advanced course ? | Vijay | Main CFD Forum | 2 | July 8, 2001 03:40 |
