Boundary Layer?
Old   September 24, 2003, 03:41
Default Boundary Layer?
P.I
I want to model a cyclone seperating devise but I am having a few concerns about the grid that I have generated. My real concern is to do with the boundary layer on the walls. I understand that by using normal wall functions, the Y+ value should be between 30 and 60, however, how do I go about generating a good initial approximation on how fine the grid at the wall should be?
Thanks
P.I
Old   September 24, 2003, 19:22
Default Re: Boundary Layer?
eva
hello, there is no such rule exist. it is always the inital guess then u should run and then see what ur results. if it is compatible with the therotical or experimental data then go a head other cahnge refine the grids more
Old   September 25, 2003, 09:55
ag
Try here -
http://geolab.larc.nasa.gov/APPS/YPlus/
[Gmsh] Default Faces on Boundary Layer axel OpenFOAM Meshing & Mesh Conversion 8 February 17, 2011 07:47
Boundary Layer Question scottneh STAR-CCM+ 3 September 30, 2010 14:21
Adapt mesh without modifying boundary layer cells? Freeman FLUENT 0 February 22, 2009 14:11
3D Boundary Layer Mario FLUENT 0 February 17, 2009 03:40
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
