help in ANDERSON text...
Old   July 14, 2009, 01:20
Default help in ANDERSON text...
atmcfd's Avatar
ATM
atmcfd is on a distinguished road
i`m going through anderson`s 'CFD and its applications",and i`m stuck on pg. 308
(analysis of quasi one dimensional subsonic-supersonic nozzle). here the initial condition of density,temperature and velocity is given by the equations
p = 1 - 0.3146x
T = 1 - 0.2314x . initial conditions at t = 0
V = (0.1 + 1.09x)T^1/2
where 'x' is the axis where the grid points are evenly spaced
forgive me if dis question`s stupid, but what is the origin of these eqns? there is no explanation offered in the text as to what are the governing principles behind these. are these just taken arbitrarily or what...
please help.
thanks in advance,
atm
atmcfd is offline   Reply With Quote
Old   July 14, 2009, 09:58
Default Initial Conditions
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
The subsonic-supersonic nozzle appears in Modern Compressible Flow, 2nd Edition, Anderson, pp. 365 (The Time-Marching Technique) with the following quote:
"...the guessed initial temperature distribution at time t=0. It is arbitrarily taken as linear variation."
I presume it's likely the same example in your book "CFD and its Application."
So I believe all the initial values are based on knowing the solution, so they have no theoretical foundation. They are probably chosen to be just close enough to the final (known) solution to make your solver work, but not far enough away to cause problems.
If you are following along and writing your own solver I would suggest substituting fixed values and see what converged solution you get.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   July 14, 2009, 11:26
atmcfd's Avatar
ATM
thank u very much...
is it better if i write my computer code in C++ or MATLAB?
how do the 2 differ?
thanks in advance.
atm
Old   July 14, 2009, 14:09
RenardP is on a distinguished road
Since your problem is 1D you can use C++ or Matlab. For 2D and 3D problems Matlab is simply to slow.
Use the language you are more familiar C++ or Matlab for this simple problem.
RenardP is offline   Reply With Quote
Old   July 15, 2009, 01:11
atmcfd's Avatar
ATM
oh... thank u very much.i guess C++ is better.
Thread Tools
Trackbacks are On
DPM Particle tracks summary text input Rajesh Gutti FLUENT 1 October 17, 2008 02:29
Fluent in text mode Aris FLUENT 1 April 15, 2008 07:13
Saving velocity contours to a text file Craig Johansen FLUENT 1 March 6, 2007 20:07
rsm,K-epsilon models, donating text on turbulence francisco saldarriaga CFD-Wiki 1 May 19, 2006 04:54
TEXT COMMAND Alex Munoz FLUENT 0 April 10, 2003 22:32
