Flow Visualization of impinging swirling flow on the wall.
Old   March 26, 1999, 00:22
Default Flow Visualization of impinging swirling flow on the wall.
sangaria
I have done experiments on flow visualization of impinging flow on the wall with a great swirl velocity.
In detail, I set up a test rig with 3cm diameter fan for cpu cooling and a transparent flat plate under the fan to take a picture. At first, I make smoke by burning paraffin with somke generator and I direct smoke with tube to the fan inlet. I can see some smokes after fan outlet but hardly I can take pictures of smoke after fan inlet. I think the strength of wind id too string enought to see the somke with eyes or by taking pictures.
So, I wanna know the method for flow visualization.. of micro cooling fan for PC processor, without any special apparatus..I have only a smoke generator, a camera and a camcoder. The velocity of flow is 1[m/s] so it is too low for usual flow visualization methods.
thanks
Old   March 26, 1999, 00:25
Default Re: Flow Visualization of impinging swirling flow on the wall.
sangaria
There are too many typos. So, I rewrote it. Sorry..
In detail, I set up a test rig with 3cm diameter fan for cpu cooling and a transparent flat plate under the fan to take a picture. At first, I make smoke by burning paraffin with smoke generator and I direct smoke to the fan inlet with tube. I can see some smokes after fan outlet but hardly I can take pictures of smoke after fan outlet. I think the strength of wind is too strong enough to see the somke with eyes or by taking pictures.
Old   March 26, 1999, 13:31
andy
I cannot help directly but I have seen this sort of problem discussed fairly often on the sci.mech.fluids newsgroup. It may be worth repeating your request there.
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
how to calculate flow properties along the first grid point near to the wall kiran OpenFOAM Post-Processing 2 September 12, 2010 12:59
Wall pressure interpolation for buoyant flow khaiching Main CFD Forum 2 April 28, 2010 21:04
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 21:03
Manipulating flow speed at wall Salman FLUENT 0 April 17, 2003 18:32
