-   -   fortran common block (http://www.cfd-online.com/Forums/main/6656-fortran-common-block.html)
A.M.Memarzadegan October 4, 2003 06:17
Hi every body, I have a cfd code which declares variables through common block in a file named common.inc I can't add variables to it.for instance i want to increase some integer variables. What sould i do?
Jim Park October 4, 2003 09:31
Re: fortran common block
Don't understand the question. Why can't you add variables? Certainly FORTRAN allows for common blocks to be modified. Are you reading/writing files whose size and structure are tied to the size and structure of the common block?
A.M.Memarzadegan October 4, 2003 09:47
Yeap It is realy amazing.when i add a line to declare other bunch of variables i face to lexical error(unrecognized statement) i want to add following line 2 ni1,ni2,nj1,nj2 under 1/alli/ni,nj,... in following file.
parameter(it=32,jt=32,kt=32,nphit=11)
common
1/pres/ipref,jpref,kpref
1/prin1/plane
1/prin2/indmon,imon,jmon,kmon
1/vecti/nsweep(nphit)
1/vectl/solve(nphit)
1/vectc/head(nphit)
1/vectr/phi(it,jt,kt,nphit),phio(it,jt,kt,nphit),prt(nphit ),
2 resor(nphit),reref(nphit),urf(nphit),ex(it),
3 deksi(it,jt,kt),deeta(it,jt,kt),dezeta(it,jt,kt),
4 dnksi(it,jt,kt),dneta(it,jt,kt),dnzeta(it,jt,kt),
5 dhksi(it,jt,kt),dheta(it,jt,kt),dhzeta(it,jt,kt),
6 conve(it,jt,kt),convn(it,jt,kt),convh(it,jt,kt),
7 smp(it,jt,kt),dtfals(nphit)
1/alli/ni,nj,nk,nim1,njm1,nkm1,iter,maxit,nphmax,itstep,n tstep
1/allr/great,small,sormax,betap,time,dt(10000),phimax(nph it),
2 phimin(nphit),dtv(it,jt,kt)
1/allc/scheme,schtur,name
1/alll/save,restrt,cycl,ortogo,steady,echo,wallq,polar
common
1/geom/xc(it,jt,kt),yc(it,jt,kt),zc(it,jt,kt),vol(it,jt,k t),
2 areaex(it,jt,kt),areaey(it,jt,kt),areaez(it,jt,kt) ,
3 areanx(it,jt,kt),areany(it,jt,kt),areanz(it,jt,kt) ,
4 areahx(it,jt,kt),areahy(it,jt,kt),areahz(it,jt,kt) ,
5 fx(it,jt,kt),fy(it,jt,kt),fz(it,jt,kt),
6 xp(it,jt,kt),yp(it,jt,kt),zp(it,jt,kt)
1/flupr/urfvis,viscos,densit,den(it,jt,kt),vis(it,jt,kt)
1/turb/cmucd,cmu,cd,c1,c2,cappa,elog,pfun,prandl
1/coef/ap(it,jt,kt),an(it,jt,kt),as(it,jt,kt),ae(it,jt,kt ),
2 aw(it,jt,kt),ah(it,jt,kt),al(it,jt,kt),
3 su(it,jt,kt),sp(it,jt,kt)
1/coefge/xksi(it,jt,kt),xeta(it,jt,kt),xzeta(it,jt,kt),
2 yksi(it,jt,kt),yeta(it,jt,kt),yzeta(it,jt,kt),
3 zksi(it,jt,kt),zeta(it,jt,kt),zzeta(it,jt,kt)
1/point/Tin,uin,u,v,w,p,pp,m,te,ed,t,f1,f2,f3
integer u,v,w,p,pp,m,te,ed,t,f1,f2,f3
logical solve,save,restrt,cycl,steady,ortogo,echo,wallq,po lar
character plane*2,head*24,scheme*2,schtur*2,name(nphit)*2 c end
TPallidum October 4, 2003 12:35
Make sure the leading 2 in the new line is in the correct column for continuation and that there is a comma before ni1.
