Non dimensionalized Length
Like Tree1Likes
  • 1 Post By sbaffini
Old   November 27, 2020, 03:04
Default Non dimensionalized Length
Mateja
Mateja is on a distinguished road
Hello, I am developing a FORTRAN code for flow in a channel and pipe. The equations are non dimensionalized. My question is which length should be taken as reference length to make the length and width of the channel non dimensionalized? diameter of the tube or height of channel would be an appropriate reference?
Also for velocity, Which reference velocity can be used to get the non dimensionalized numbers eg. Reynolds number?
Is there any reference for this?
Thank you.
Mateja is offline   Reply With Quote
Old   November 27, 2020, 09:51
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
While I am, typically, against writing nondimensional codes today (you get the confusion you have but not any practical advantage), I think you are overthinking this.
When doing a simulation, you need to have a dimension and a velocity that are both 1. Those will be the ones in your Re definition. Let's say you have a pipe diameter of 2 and a Re of 100, that Re necessarily refers to the pipe radius and not the diameter.
For channels and pipes you will likely find both cases (half height/radius and full height/diameter). Just stick to whatever reference you think is appropriate for your work.
aero_head likes this.
sbaffini is offline   Reply With Quote
Old   December 1, 2020, 03:02
Mateja
Thank you for your reply @sbaffini.
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 04:47
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 06:04
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Modelled Length Scale in SAS-SST Simulation jego Main CFD Forum 0 January 16, 2016 06:45
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 04:50
