overpridiction of reattachment point
Old   October 9, 2003, 06:58
Default overpridiction of reattachment point
A.M.Memarzadegan
Dear All, I solved backward facing step of kim et al geometry.1:3 step hight to whole diameter and 28*step hight whole length and 4*step hight inlet of step using k-eps (wall function) by a collocated simplec code. the reattachment point is around 9.4 .i don't know the reason of this overestimation instead of underpridiction.i prescribed k & eps at inlet but used uniform velocity inlet. at Re=69610.
Looking forward to hearing from you
Old   October 14, 2003, 11:46
Default Re: overpridiction of reattachment point
BAK_FLOW
there could be lots of reasons and the task at hand it to evaluate your solver and the implementation of the models, preferably one thing at a time.
I would first suggest doing some of the standard laminar benchmark solutions. Have you tried the laminar backward facing step? How about some of the other standard laminar cases such as the lid-driven cavity, Couette flow and other cases with analytical solutions, etc. You should be able to convice yourself that the code performs as expected ie. if you have implimented a second order scheme that it does perform as such. Also of importance is that you understand and can control the iteration errors, etc.
Once you have determined that your code performs well on the laminar cases then you can move on to simple turbulent cases ie flat plate boundary layers, mixing layer, etc.
Hope this helps.
Bak_Flow
Old   October 14, 2003, 16:12
A.M.Memarzadegan
Thanx for your answer.yes i have tried laminar step as well as cavity.the code functions well with laminar.but in turbulence no.i think the problem is out of my mesh. i don't know how i can find a good mesh.mybe by trail and error. anyway i am still trying to find a suitable mesh.maybe a solved problem can be a good hint and help.
Old   June 7, 2010, 02:27
MAZI
mazdak is on a distinguished road
dear Memarzadegan
Do you have any benchmarks that estimate reattachment point behind an obstacle in turbulent channel flow?
mazdak is offline   Reply With Quote
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
compute the reattachment point Ralf Schmidt Main CFD Forum 1 April 6, 2006 16:09
overpridiction of reattachment point A.M.Memarzadegan Main CFD Forum 0 October 5, 2003 17:05
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
