direct numerical simulation
hi
My project is "the study of multiparticle systems in a fluid using Direct Numerical Simulation".....i basically need help because i dont from where to start...im suppose to write my own code..i have entierly no clue ..please any help thanks my email: zobekenobe@gmail.com |
DNS - Turbulence Modeling
hello,
just to share with you, even I am working on a similar turbulence problem i.e. JICF. I am also supposed to use DNS, the way I am looking at it is like one first needs to understand the basic turbulence model & the special cases where one uses these models. make some literature survey on this work, search for good research papers, they are available on net. You will get a good start, good luck. |
