-   -   pressure coorection (http://www.cfd-online.com/Forums/main/67065-pressure-coorection.html)
rr_amerian August 3, 2009 01:59
pressure coorection
Hello all,
I am a PhD student, writing a CFD code for a laminar flow in cylindrical axisymetric coordinate. I can not converge my code:( and I think the problem is in exerting boundary conditions of pressure correction equation.
I will be so thankful if anybody can send me the boundary conditions of Pressure correction equation in SIMPLE algorithm.
Thanks everybody.
Good Luck
m.iran August 20, 2009 04:54
RE. Pressure correction equation in SIMPLE algorithm
Normaly there are 2 kinds of conditions at boundary, either the pressure at boundary is given and normal velocity is unknown or vice versa.
1.Given pressure : if guessed pressure field is arranged such that at boundary P*= Pgiven, then value of the P' at the boundary will be zero.
2.Given normal velocity: for example if the velocity has be given just at western face, just the coefficient of aw at pressure correction Eq will be zero, and other coefficients don't change. and u* at west shouldn't be corrected. (because it is given as boundary condition and does not change) :cool: it is illustrated in Numerical heat transfer and fluid flow by patankar.
SKK August 20, 2009 05:41
Have a look at the book 'An introduction to computational fluid dynamics, the finite volume method' by H. K. Versteeg & W. Malalasekera.
