October 20, 2003, 07:58 |
Thermo-acoustics
Somebody working in the field of thermo-acoustics? Pr
October 20, 2003, 08:02 |
Re: Thermo-acoustics
we have worked on pulse tubes?
October 20, 2003, 08:14 |
Can you elaborate on that pulse tubes.? Pr
October 21, 2003, 04:44 |
Essentially it is a thermoacoustic engine that provides pulsating flow down a tube to provide cooling. Similar to a reverse stirling cycle without the moving parts
October 21, 2003, 04:56 |
Oscillating pressures inside a tube closed at one end will cause the gas to be heated at the closed end during compression and cooled at the other end during expansion. Basic refrigeration cycle
October 21, 2003, 05:02 |
Okay thanks. But I was referring to self excited oscillations produced from therm-acoutics coupling in gas turbine combustor. Which is a problem of concern nowadays in the disgn of Low Nox gas turbine combustor.
October 21, 2003, 09:07 |
Does this mean that
Pr = Pratap ? |
October 21, 2003, 09:21 |
Yeah
October 24, 2003, 10:49 |
#9 |
Clients of us have been working with RADIOSS-CFD to produce some thermal acoustic flow in a gaz turbine.
I can provide the published paper by e-mail if needed. 'Numerical Analysis of acoustic-flow interaction in a gas turbine combustion chamber' Dariusz Nowak ALSTOM Dimitri Nicolopoulos dimitri@mcube.fr www.mcube.fr |
Display Modes | |
Adding Thermo to basicKinematicCollidingCloud | bruce | OpenFOAM Programming & Development | 12 | July 7, 2022 11:23 |
urgent!!! surface dpdt values in acoustics | samad87 | FLUENT | 0 | August 31, 2009 23:53 |
How to solve acoustics ? | wolle1982 | OpenFOAM Running, Solving & CFD | 8 | May 18, 2009 04:20 |
Unsteady modelling - AMG divergence + acoustics | Neville | FLUENT | 0 | September 3, 2004 00:21 |
Acoustics in Fluent | Nurul Murad | FLUENT | 0 | April 1, 2004 22:11 |
