November 15, 2003, 07:28 |
non-dimensional values(-uv/u0^2...
Hi everybody, I have solved channel flow using k-eps wall function.I am to print non-dimensional values.particulary i wonder how i should calculate total stress and turbulent shear stress.that is -uv/umax**2 to/umax**2 actully i have calculated them but it seems there are not correct i wonder if i calculated them correctly. my code is collocated and viscosity and other values are in same node. would you tell me how i should interpolate and calculate them assuming that i have all vales in each node take care
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
max node values exceed max element values in contour plot | jason_t | FLUENT | 0 | August 19, 2009 11:32 |
exact face values | RubenG | Main CFD Forum | 0 | June 22, 2009 11:09 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 08:56 |
