September 3, 2009, 22:09 |
Boundary layer strategy for port flow case?
Digital_Junkie
I need some advice on setting up boundary layers for an automotive port flow case. The case I'm working on now is an intake port. The inlet/outlet pressure differential is 6975 Pa. I'm using a realizable k-epsilon model and the case has about 3 million cells. Minimum cell size in the valve clearance area is .25 mm. Valve lift (2 valves) is 14 mm. Can someone please provide some guidance on how many prism layers to use and how to size them? Thank you for your time.
September 9, 2009, 06:09 |
Digital_Junkie
Can anyone please give me some guidance?
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
boundary layer thickness for pipe flow | ranjith | CFX | 4 | September 13, 2015 22:29 |
Is boundary layer "a must" in turbulence flow? | Pingaroo | FLUENT | 3 | May 25, 2009 11:09 |
2D Boundary Layer Development in CFX11 | Chris Basciano | CFX | 1 | August 28, 2008 16:15 |
Boundary layer flow goes the wrong way | andimb | OpenFOAM Running, Solving & CFD | 2 | March 20, 2006 08:51 |
