September 9, 2009, 12:56 |
About a two phase simulation (gas-solid)
Fernando Herrera
Rep Power: 17 |
Hi, I was wondering if you could give me some advise regarding modeling of two phases system.
In my system, there is a solid reacting with a gas that is flowing inside the equipment. I have already developed a code that simulates the solution but, due the mass interaction between the gas and solid, the sum of the mass fractions is not always one. I am addressing this problem by adjusting the density of the gas and solid with a mass balance and not with the ideal gas law. I havent finished the code, but, while working on it I found something that I would like to have some advise about it. What I have done is to discretise the mass balance equation: d(Rho)/dt + d(Rho Vel)/dx = S into this with an upwind approach (Ap)(RhoP) = (Ae)(RhoE) + (Aw)(RhoW) + Sc where: Aw = max( VelW*Area, 0) Ae = max( -VelE*Area, 0) Ap = Aw + Ae + (VelE * Area - VelW * Area) + dt/dv - Sp Sc = Sdt + dt/dv (Rho`) My question is, in the central coefficient (Ap), when I use the term (VelE * Area - VelW * Area) the solution doesnt make sense at all. When it is removed, the solution makes more sense. What could be the reason for that? and, is this a good approach for the solution of a reacting system like this one?? Please, any help will be appreciated |
Exhaust Gas manifold simulation | shrinath | Siemens | 6 | September 5, 2013 16:26 |
solid liquid phase change (melting/solidification) | ernane | CFX | 0 | February 3, 2009 14:24 |
Viscosity for solid dispersed phase in E-E modelin | Kushagra | FLUENT | 0 | June 27, 2008 19:01 |
allowed gas phase escape | Abu-Khawlah | FLUENT | 0 | August 20, 2005 10:14 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
